Acum este Vin, 13-Noi-2026 10:08
 Subiectul mesajului: DYNPRO_FIELD_CONVERSION
MesajScris: Mar, 21-Aug-2007 17:22
Salve! :)
Am urmatoarea problema: "sunt" intr-un smartform si ma uit intr-un template. Dau pe scrool sa ajung la ultima linie si imi apareo eroarea: DYNPRO_FIELD_CONVERSION :cry:
Runtime Errors DYNPRO_FIELD_CONVERSION
Date and Time 21.08.2007 16:10:12
ShrtText
A conversion error occurred.
What happened?
The current screen processing was terminated, since a situati
occurred from which it could not continue processing.
This is probably due to an error in the current screen of the
program.
to screen 1095. This error made it impossible to finish execu
remainder of the program.
Error analysis
The program flow was interrupted and could not be resumed.
Program "SAPLSTXB" tried to display fields on screen 1095. Ho
error occurred while this data was being converted.
Are cineva idee care este cauza?si ce pot face in continuare?
:shock:
