Acum este Vin, 13-Noi-2026 10:43
MesajScris: Lun, 27-Aug-2007 10:59
Salve! :)
Are cineva idee de ce apare eroarea asta la rularea tranzactiei FBCJ?
Runtime errors SAPSQL_ARRAY_INSERT_DUPREC
Exception CX_SY_OPEN_SQL_D
B
Occurred on 27.08.2007 at 10:54:47
The ABAP/4 Open SQL array insert results in duplicate database records.
What happened?
Error in ABAP application program.
The current ABAP program "SAPLF049" had to be terminated because one of the
statements could not be executed.
This is probably due to an error in the ABAP program.
Error analysis
An exception occurred. This exception is dealt with in more detail below
. The exception, which is assigned to the class 'CX_SY_OPEN_SQL_DB', was
neither
caught nor passed along using a RAISING clause, in the procedure
"RELATION_SAVE" "(FORM)"
Since the caller of the procedure could not have expected this exception
to occur, the running program was terminated.
The reason for the exception is:
If you use an ABAP/4 Open SQL array insert to insert a record in
the database and that record already exists with the same key,
this results in a termination.
(With an ABAP/4 Open SQL single record insert in the same error
situation, processing does not terminate, but SY-SUBRC is set to 4.)
mult'am,
MesajScris: Lun, 27-Aug-2007 15:28
Vezi ca sunt cateva note OSS pentru chestia asta - cauta erroarea cu "SAPLF049".
Nu stiu ce versiune de SAP sau patch level ai ca sa vad care e problema la tine.
MesajScris: Mar, 28-Aug-2007 14:37
salut!
am incarcat cateva note..se pare ca eroarea era din cod de abap...
s-a cam rezolvat acum :D
Utilizatorii ce navighează pe acest forum: Niciun utilizator înregistrat şi 69 vizitatori
