| err SAPSQL_ARRAY_INSERT_DUPREC in tranzactia FBCJ https://sap-consulting.ro/phpbb/viewtopic.php?f=1&t=497 |
| Autor: | Mihaela [ Lun, 27-Aug-2007 10:59 ] |
| Subiectul mesajului: | err SAPSQL_ARRAY_INSERT_DUPREC in tranzactia FBCJ |
Salve! Are cineva idee de ce apare eroarea asta la rularea tranzactiei FBCJ? Runtime errors SAPSQL_ARRAY_INSERT_DUPREC Exception CX_SY_OPEN_SQL_DB Occurred on 27.08.2007 at 10:54:47 The ABAP/4 Open SQL array insert results in duplicate database records. What happened? Error in ABAP application program. The current ABAP program "SAPLF049" had to be terminated because one of the statements could not be executed. This is probably due to an error in the ABAP program. Error analysis An exception occurred. This exception is dealt with in more detail below . The exception, which is assigned to the class 'CX_SY_OPEN_SQL_DB', was neither caught nor passed along using a RAISING clause, in the procedure "RELATION_SAVE" "(FORM)" . Since the caller of the procedure could not have expected this exception to occur, the running program was terminated. The reason for the exception is: If you use an ABAP/4 Open SQL array insert to insert a record in the database and that record already exists with the same key, this results in a termination. (With an ABAP/4 Open SQL single record insert in the same error situation, processing does not terminate, but SY-SUBRC is set to 4.) mult'am, Mihaela |
| Autor: | cata_nasty [ Lun, 27-Aug-2007 15:28 ] |
Vezi ca sunt cateva note OSS pentru chestia asta - cauta erroarea cu "SAPLF049". Nu stiu ce versiune de SAP sau patch level ai ca sa vad care e problema la tine. Succes, Cata |
| Autor: | Mihaela [ Mar, 28-Aug-2007 14:37 ] |
salut! am incarcat cateva note..se pare ca eroarea era din cod de abap... s-a cam rezolvat acum |
