Acum este Vin, 13-Noi-2026 10:08
 Subiectul mesajului: eroare activare BC Set
MesajScris: Mie, 29-Aug-2007 14:47
Am o eroare la activarea unui BC set(cu tranzactia SCPR20).
Runtime Errors GETWA_NOT_ASSIGNED
Date and Time 29.08.2007 14:17:17
ShrtText
Field symbol has not yet been assigned.
What happened?
Error in ABAP application program.
The current ABAP program "SAPLSCPRHI" had to be terminated because one of the
statements could not be executed.
This is probably due to an error in the ABAP program.
Error analysis
You attempted to access an unassigned field symbol
(data segment 32787).
This error may occur for any of the following reasons:
- You address a typed field symbol before it is set using ASSIGN
- You address a field symbol that points to a line in an internal table
that has been deleted
- You address a field symbol that had previously been reset using
UNASSIGN, or that pointed to a local field that no longer exists
- You address a global function interface parameter, even
though the relevant function module is not active,
that is it is not in the list of active calls. You can get the list
of active calls from the this short dump.
Trigger Location of Runtime Error
Program SAPLSCPRHI
Include LSCPRHI$04
Row 5
Module type (FUNCTION)
Module Name SCPR_HI_ACTLINKS_UPDATE
Are cineva idee de ce apare eroarea si cum sa o corectez? exista o nota SAP pt. ea? (eu am incercat cateva note dar nu am reusit).
