| Eroare AFAB https://sap-consulting.ro/phpbb/viewtopic.php?f=3&t=741 |
| Autor: | ionutz36 [ Mie, 06-Ian-2010 12:25 ] |
| Subiectul mesajului: | Eroare AFAB |
Salut, Am incercat sa rulez amortizarea (AFAB) pe o luna si imi apare urmatoarea eroare: "Field Cost Ctr is a required field for G/L account BP01 28131000 Message no. F5808 Diagnosis The value for field "Cost Ctr" in the interface to Financial Accounting is an initial value but you are required to make an entry in the field selection for G/L account "28131000" in company code "BP01" linked to the field selection for posting key "70". System response Error Procedure It might be an error in the configuration of the G/L account field selection. The initial application, used to call up the interface must otherwise define a value for field "Cost Ctr". If this is the case, contact the consultant responsible for the application used to call up the interface or get in contact with SAP directly." M-am uitat in fs00 dar nu am gasit nimic care sa ma ajute si nu stiu ce treaba are cost center-ul la contul 2813. Am mai incercat si in OB41 pentru cheia 70 dar nu prea ma prind ce poate sa fie. Daca aveti vreo idee va rog nu ezitati. Multumesc, Ionut |
| Autor: | prejban.sorin [ Joi, 07-Ian-2010 15:29 ] |
| Subiectul mesajului: | Re: Eroare AFAB |
Salut, Incearca in definitia contului 28131000 in tranzactia FS00 la Grup de setari camp sa introduci un grup in care campul "Centru de cost" sa aiba bifa "intrari optionale". Apoi reruleaza amortizarea. Sorin |
| Autor: | ionutz36 [ Vin, 08-Ian-2010 16:15 ] |
Salut, Am reusit cu OBC4. Am modificat statusul campului in "optional". Merci, |
