Acum este Vin, 13-Noi-2026 07:06
 Subiectul mesajului: tabstrip control
MesajScris: Lun, 09-Oct-2006 15:23
Locaţie: timisoara
salut
daca ma puteti ajuta,nu stiu cum sa fac vizibil/invizibil un strip (asta dinamic)
dintr-un tabstrip control.Eventual daca ma poate ajuta cineva cu structura TABSTRIP (campurile acesteia).
BZZzzzz
MesajScris: Lun, 09-Oct-2006 16:33
Uite un scurt exemplu aici :
REPORT z_test_subscreen .
CALL SCREEN 100.
CONSTANTS: BEGIN OF C_TABS,
TAB1 LIKE SY-UCOMM VALUE 'TAB1',
TAB2 LIKE SY-UCOMM VALUE 'TAB2',
END OF C_TABS.
CONTROLS: TABS TYPE TABSTRIP.
DATA: BEGIN OF G_TABS,
SUBSCREEN LIKE SY-DYNNR,
PROG LIKE SY-REPID VALUE 'Z_TEST_SUBSCREEN',
PRESSED_TAB LIKE SY-UCOMM VALUE C_TABS-TAB1,
END OF G_TABS.
DATA: ok_code LIKE sy-ucomm.
*& Module STATUS_0100 OUTPUT
MODULE status_0100 OUTPUT.
SET PF-STATUS 'PF-100'.
* SET TITLEBAR 'xxx'.
ENDMODULE. " STATUS_0100 OUTPUT
*& Module USER_COMMAND_0100 INPUT
MODULE user_command_0100 INPUT.
CASE ok_code.
WHEN 'BACK'.
LEAVE PROGRAM.
ENDCASE.
ENDMODULE. " USER_COMMAND_0100 INPUT
*& Module ACTIVE_TAB_SET OUTPUT
module ACTIVE_TAB_SET output.
TABS-ACTIVETAB = G_TABS-PRESSED_TAB.
CASE G_TABS-PRESSED_TAB.
WHEN C_TABS-TAB1.
G_TABS-SUBSCREEN = '0101'.
WHEN C_TABS-TAB2.
G_TABS-SUBSCREEN = '0102'.
WHEN OTHERS.
ENDCASE.
endmodule. " ACTIVE_TAB_SET OUTPUT
*& Module active_tab_get INPUT
module active_tab_get input.
CASE OK_CODE.
WHEN C_TABS-TAB1.
G_TABS-PRESSED_TAB = C_TABS-TAB1.
WHEN C_TABS-TAB2.
G_TABS-PRESSED_TAB = C_TABS-TAB2.
WHEN OTHERS.
ENDCASE.
endmodule. " active_tab_get INPUT
iar in screenul 100 ai urmatoare bucata :
PROCESS BEFORE OUTPUT.
MODULE active_tab_set.
CALL SUBSCREEN tab_ref1 INCLUDING sy-repid g_tabs-subscreen.
MODULE status_0100.
PROCESS AFTER INPUT.
CALL SUBSCREEN tab_ref1.
MODULE active_tab_get.
MODULE user_command_0100.
Trebuie in plus sa mai creezi screenurile 101 si 102 (sub screenuri) si statusul PF-100.
Sper sa mearga!
Succes!!!
MesajScris: Mie, 11-Oct-2006 18:41
Locaţie: timisoara
Salut
Mersi de ajutor , imi merge si mie :)
BZZzzzz
